Sim Caching with Apprentice - issues?
Hi there
I'm caching out a fluid sim from the dop network using an output node and then playing back the sim thru a dop network node.
My problem is I'd swear the the cached result is different to what I see if I just play back the sim as it is in memory after running thru.
What plays back with a blue line in the time line is different to the purple line and of course once i load up the cached to disk sim I can't get back to the blue line without playing the sim thru again which is maybe 4 or 5 hours.
Is this even possible?
I've seen a few posts saying that the dynamic rop doesn't work with apprentice, if that's the case I guess that could be my issue?
thanks
Nigel.
