nearest pt num
I'm using Houdini 15, and i'm following CmiVfx Connections tutorial, chapter 4 where you create sphere and grid and a vop sop wich is suposse to tell which point from the sphere is closest to which point on the grid. I know things changed with the latest H release, and i thought i kind of a figured it out, but all i get is constant number and it's not point number that is closest to anything. I'va attached the file, if anyone can look inside and tell me what i'm missing?
nearestPTNUM.hip
thank you so much Bunker! :D so easy.. still got a loooot to learn. :)
and how about other attributes like distance between 2 points, normals, position, color, alpha? can it all be done in attribute wrangle node or is this suposse to be done in pc import?
getting attributes is easy, now that you have the point number, you can use the "point" function:
int closestpoint = nearpoint(1,@P);
v@Cd=point(1,"Cd",closestpoint);
or in just one line:
v@Cd=point(1,"Cd",nearpoint(1,@P));
using pointclouds you can limit the search radius:
float radius = 1;
int maxpoints = 1;
int handle = pcopen(1,"P",@P,radius,maxpoints);
// import Cd from first point from second input
@Cd = pcimportbyidxv(handle,"Cd",0);
you'll have to replace pcimportbyidxv if the attribute is a float for example: pcimportbyidxf
or in one line:
@Cd = pcimportbyidxv(pcopen(1,"P",@P,1,1),"Cd",0);
getting the distance is easy:
vector P2 = pcimportbyidxv(pcopen(1,"P",@P,1,1),"P",0);
float dist = distance(@P,P2);
