Obtaining position from dop by python
joefit
Hi!
I'm new in Houdini and I have a problem.
I created and SOP object where the animation of it is controlled through DOP object and an script of python. I trying to to record the different positions of the object through the simulation. But, always my script returning the Initial position value when the simulation runs.
This is a piece of my python script:
#Houdini Library import
import hou
#Function that allow us to set the number of playbar's frame.
def playbarFrame(frame):
     try:
         hou.setFrame(frame)
     except Exception as e:
         print type (e)
#Function that allow us to start the simulation once.
def startSimulation():
    try:
         hou.playbar.setPlayMode(hou.playMode.Once)
         hou.playbar.play()
         print type (e)
#Function that allow us to stop the simulation.
def stopSimulation():
    try:
         hou.playbar.stop()
         print type (e)
#Function that allow us know the current frame.
def currentFrame():
    try:
         return hou.frame()
         print type (e)
#Function that allow us kwow if the simulation is working.
def isWorking():
    try:
         return hou.playbar.isPlaying()
         print type (e)
#Function that return us the value of the sphere's y-axis.
def sphereMove():
     try:
         #Loading a geometry and parameters
         geo = hou.node('/obj/sphere_object1/transform1')
         #Initial value of the geometry in 'y'-axis
         geoPos=geo.geometryAtFrame(hou.frame()).boundingBox().center()[1]
         return geoPos
         print type (e)
# Main function of the script
# Description: Main function that calling functions for the control
#              of sphere.
def main():
      try:
            #If the simulation is stopped we run it.
            if isWorking()==False:
                #Initializing the crack var and the umbral var
                crack= True
                umbral= 0.5
                #Setting the playbar at first frame before the simulation start.
                if currentFrame()>1.0:
                     playbarFrame(1.0)
                #Running the simulation at first time.
                startSimulation()
                #Calling an event when the animation has started through an iteraion
                while isWorking()and crack== True:
                     pos = sphereMove()#searching value position
                     print pos
            else:
                 stopSimulation()
         print type (e)
What can I do? Where is the problem? how could I take the value from the dop node?
Thanks
Hmm...
Wrapping all those big sections of code in try/except is just asking for ambiguous operation. Remove all your try excepts so you can see where the error is occurring.
I would guess the way you are fetching the position is not really working as expected.
Is your simulation truly changing the transform1 node of the master object transformation?
Have you tried fetching the transformation parameters directly?
geo = hou.node('/obj/sphere_object1')
x = geo.parm("tx").eval()
y = geo.parm("ty").eval()
z = geo.parm("tz").eval()
It is hard to say without seeing the HIP file. Is the python node inside a network that it is trying to drive? It might be better to not "force" the simulation playback from python. Instead write your python to simply evaluate the current frame that it finds itself executing on. Then the standard timeline playback can be used to control the result.
Edited by Atom
