mimbik Posted March 11, 2016 Share Posted March 11, 2016 Hello everyone, I wanted to transfer my animation from DOPs to SOP level, but I need to have a baked Curve. I managed to make a transfer between CHOPS > SOP using dynamics and export in CHOPS, but when I click Edit Data Channels and then Fit Panel > Copy to Export Destination (9 channels), I got a message "Status: 0 channels copied." The connection between CHOPS and SOP still works, I have a curve in Motionfx editor but I can't transfer it to Animation Editor and delete CHOP Network. Please Help. Quote Link to comment Share on other sites More sharing options...
anim Posted March 12, 2016 Share Posted March 12, 2016 instead of using Export CHOP to export your channels use any CHOP make sure that it's Export Prefix + channel names point to the correct parameters you want to override and turn on Export Flag on that CHOP then Copy To Destination should work Alternatively RMB-Click on your overriden parameters and do Channels And Keyframes/Bake Keyframes, fill in the range or tweak the other settings and Accept Quote Link to comment Share on other sites More sharing options...
mimbik Posted March 12, 2016 Author Share Posted March 12, 2016 Thank You! I will check that. Quote Link to comment Share on other sites More sharing options...
mimbik Posted March 13, 2016 Author Share Posted March 13, 2016 Yes it is working It was important to use Rename CHOP and rename channels eg. from :tx to tx and give a proper path in Export Prefix. Quote Link to comment Share on other sites More sharing options...
