Ambient occlusion
Hi : ) ,
 I saw that the environment light is the new AO method for houdini since version 11.
But i want it to create only the shadow of the occlusion not lit the scene with white color
For final render i will create a different take but for testing i want to combined the AO on top of the main beauty render in a single render
How to do that?
Thanks !
you can use Occlusion VOP in your shader and use as you want
however using environment light in AO mode is preferred and easier
on the other hand AO nowadays not necessary for realistic renders unless it's your artistic choice
Is there a tutorial on how to use this shader?
