Duplicating an OTL file
How can an otl file be duplicated? I mean so I would copy the file itself so that an older version node could remain at the tab menu too.
I tried to rename the basic label but the older one not appears.
I hope I was clear
Thanks,
Bye.
G
you can't have two identical definitions active at the same time.
what you can do is create a new version
if you have an hda called myAsset.hda
you can use the Operator Type Manager (Windows > Operator Type Manager)
and open the Operator Type Libraries
select the hda you want to create a new version of
RMB and select Copy
change the Operator Name, lable and Save to Library path
this will make a new version
