Black textures in water/glass
Hi, I've been searching all over for a good solution to this problem.
I'm fairly new to Houdini and I can't believe that this is a problem to begin with.
So I'm trying to render a can with droplets on it, the can has a texture applied but the texture doesn't show up in the refractions and the transparency of the liquid.
A picture of my problem can be seen below.
As I'm used to renderers such as V-Ray and Arnold where this isn't a problem, I can't help but think I'm doing something wrong.
Help please!  :)
Check if
- you activated refraction in your shader (+ refract objects)
- have a refract roughness < 1
- Are you using raytrace/PBR?
- mantra>rendering>limits>refract limit >= 2
- can render visibility is * (not only primary)
hope it helps !
Edited by boby
