prekabreki Posted April 1, 2016 Share Posted April 1, 2016 Hi, I've been searching all over for a good solution to this problem. I'm fairly new to Houdini and I can't believe that this is a problem to begin with. So I'm trying to render a can with droplets on it, the can has a texture applied but the texture doesn't show up in the refractions and the transparency of the liquid. A picture of my problem can be seen below. As I'm used to renderers such as V-Ray and Arnold where this isn't a problem, I can't help but think I'm doing something wrong. Help please! Quote Link to comment Share on other sites More sharing options...
Guest tar Posted April 1, 2016 Share Posted April 1, 2016 Try enabling Faux Caustics under Opacity tab. Quote Link to comment Share on other sites More sharing options...
prekabreki Posted April 1, 2016 Author Share Posted April 1, 2016 On 4/1/2016 at 6:23 PM, marty said: Try enabling Faux Caustics under Opacity tab. It's already enabled Quote Link to comment Share on other sites More sharing options...
Guest tar Posted April 1, 2016 Share Posted April 1, 2016 Here's a simple test that works. Droplet.hiplcFetching info... Quote Link to comment Share on other sites More sharing options...
boby Posted April 1, 2016 Share Posted April 1, 2016 (edited) Check if - you activated refraction in your shader (+ refract objects) - have a refract roughness < 1 - Are you using raytrace/PBR? - mantra>rendering>limits>refract limit >= 2 - can render visibility is * (not only primary) hope it helps ! Edited April 1, 2016 by boby Quote Link to comment Share on other sites More sharing options...
loopyllama Posted April 1, 2016 Share Posted April 1, 2016 It is tough to tell from the image. Another guess is that it has non-fresnel reflections at 100%, thus you would never see through the droplets. If that is the case, reduce the reflections and/or use fresnel on the reflections. Quote Link to comment Share on other sites More sharing options...
prekabreki Posted April 1, 2016 Author Share Posted April 1, 2016 Thanks guys for the suggestions. It started to work properly after I added a Caustic Light in the scene. Not sure why Faux Caustics didn't work, but I'm not gonna complain Quote Link to comment Share on other sites More sharing options...
fathom Posted April 1, 2016 Share Posted April 1, 2016 i would just not have the water droplets cast shadows (remove them from the shadow mask of your lights). Quote Link to comment Share on other sites More sharing options...
