pop grains following a deforming mesh
Hello,
I would like to know if that approach is possible using PDB and the new grain solver:
1. Create a Granular solid from a VDB animated mesh and make all the grains move acording to its deformation and position.
2. Break some of the constrains so that some particles will no longer follow the VDB mesh.
Thank you!
Edited by pau22
grains can be pretty unstable when they intersect with each other.  deforming would very likely lead to loads of particle intersections.  you'd probably have to adjust radii to avoid intersections prior to activation...
Here is what I was thinking you could do in DOPs.
Use a popwrangle, popvop, or sopsolver to get the rest value (the animated position).
Then animate the "activation" any way you want in SOPs. When the particle is activated, dont use the rest anymore.
Thanks Ryan, that's awesome! it works really well.
You've made my day!
