draganbaja Posted April 5, 2016 Share Posted April 5, 2016 Im trying to achieve this kind of look: http://31.media.tumblr.com/tumblr_ldrnj3TJZo1qasq3to1_r2_500.gif that black whispy trailI tried using particles whit some forces and then converting them to volume using isoOffset, but i cant get to look like this in gif. What is the best way to make it like that?tnx smoke_v003.hipnc Quote Link to comment Share on other sites More sharing options...
ciliath Posted April 5, 2016 Share Posted April 5, 2016 You'll need to simulate some smoke. Here's a good basic tutorial to get you started https://vimeo.com/38288672 Quote Link to comment Share on other sites More sharing options...
sebkaine Posted April 5, 2016 Share Posted April 5, 2016 (edited) you have basically 4 pass there. the key element is the POP sims that propagate along the curves with some curl noise and very short life span you use that as an emitter of density / vel / temp in your fluids with dissipation and disturbance + high confinment in the fluid you use your POP sims as a tracker in your auto-resize from those POP you also generate a ribbon pass that are basically POP trail mesh as a single sided polygon ribbon with a facing ratio shader with low opacity you can additionally generate a sheet pass by using your POP to generate soft body mesh were you also put a facing ratio shader ( this looks like an animated cloth mesh ) you also render your pop sim with high blur and you mix in comp - your fluids - your POP with high motion blur + low opcaity - your ribbon pass - your sheet pass in order to optmise things you can simulate straight line and deform them after , i know you can lattice a fluid in H, but i never did it so you will have to check on od force. cheers E Edited April 5, 2016 by sebkaine Quote Link to comment Share on other sites More sharing options...
draganbaja Posted April 6, 2016 Author Share Posted April 6, 2016 (edited) tnx guys you helped me a lot this is what i managed to create, but it doesnt look whispy what am i doing wrong smoke_v004.hipnc Edited April 6, 2016 by draganbaja Quote Link to comment Share on other sites More sharing options...
sebkaine Posted April 9, 2016 Share Posted April 9, 2016 (edited) hi dragan i have assemble a quick setup that describe the basic process. cheers E whipsy_001.hiplc Edited April 9, 2016 by sebkaine 1 Quote Link to comment Share on other sites More sharing options...
