Arthur Spooner Posted April 7, 2016 Share Posted April 7, 2016 What is geoHandler() function ? Quote Link to comment Share on other sites More sharing options...
anim Posted April 7, 2016 Share Posted April 7, 2016 (edited) there is no such function if you are refering o geohandle, which is an attribute of many geometry functions, than that is a pointer to the geometry you want to do operations on that pointer is either index of the input (0,1,2,3,...) or string containing path to the geometry file on disk or to an operator using op: syntax if you refer to geoself() function, that returns the geohandle to currently processed geometry, which in CVEX based sops operators currently equals to 0 as geometry from first input Edited April 7, 2016 by anim Quote Link to comment Share on other sites More sharing options...
