How do i use a if block with in a while loop to add point to group?
Hello all
Hope you guys can help me out, still learning H15. and was doing a old tut from H12 (there's some good tips in them)
with in a glue net work, i added a point vop to do a search radius to add to a group.
pc_open-> While_loop(pc_iterate -> if block(....this is where i am stuck
i read online i can use the set attribute to add a point to the group.
I am not sure how to add the set attribute inside the if block that is inside he while loop.
hope i am making this clear.
any thoughts
Edited by angelous4x
