Attribute transfer using PcOpen FAILING!
yashpolke
Hello all!
So, I am animating a sphere with red colour and transferring that colour to a black grid. Using a solver I then create a lag of the colour value on the grid.
The first method I use is ofcourse the Attribute Transfer SOP. This method works great and is perfect
The second method I use is a wrangle and I do a pcfilter by Cd and transfer the colour
Now the problem using this method is that when I do this transfer of attrib in the solver, it does not create a lag as I expect it to, like the attrib transfer SOP and I am curious as to why that is happening
Hopefully someone has the answer to this, any help would be greatly appreciated!
-Yash
post-11792-0-46112900-1460277522_thumb.j
post-11792-0-55592200-1460277525_thumb.j
attribTransLag.hipncFetching info...
You are not adding to the existing @Cd values in your wranlge, just add a "+=" to your line:
v@Cd += pcfilter( handle, "Cd" );
which is the same as:
v@Cd = @Cd+pcfilter( handle, "Cd" );
Edited by Yader
