How to create a center curve from points
aoisaki
Here's one way to define a spine curve along a spray of particles that have been hit.
-store the hit time as @firsttime
-normalise that, store it as @u
-quantize @u to the amount of points you want along the curve. now there's patches of points that share the same @u
-add prims by attribute @u, now you have little polyline islands that have the same @u value
-promote the average @P to prim, then back down as @Pavg
-set @P as @Pavg, fuse. Now each island has been collapsed to a single point at its average center
-sort these points by @firsttime so they're in order
-add prim, this will make the line
-smooth
pop_curve_center.hipnc
Edited by mestela
  • Like 4
-smooth
attachicon.gifpop_curve_center.hipnc
wow!Thank you very much!
It's perfect!
-smooth
sorry for bothering you again.
How can i use this center curve to define the vector like the picture 2.
-set each point normal to {0,1,0}
-get closest point on the curve (a)
-get the next point on the curve (a+1)
-vector along the curve is b - a
-vector away from the curve for each point is a - @P
-add those vectors to @N, scale to taste
would need further refining no doubt, but that's the general idea. :)
pop_curve_center_normal.hipnc
post-7292-0-85846000-1460496365_thumb.gi
Edited by mestela
attachicon.gifpop_curve_center_normal.hipnc
wow! thank you very much!
you rock!
