kstrev Posted April 13, 2016 Share Posted April 13, 2016 Hi guys, I am trying to assign a custom value on the lookup parameter in the wire capture node so that I can get a custom radius. I have created a primitive attribute named u but I can't figure out how to connect it to the lookup attribute. I've been reading the help pop up but I am still confused. Any thoughts? I have attached a simple test scene. Thank you wireCapture_v001.hip Quote Link to comment Share on other sites More sharing options...
edward Posted April 13, 2016 Share Posted April 13, 2016 Sorry, I don't have time to look at your hip file but the WireCapture SOP only supports customizing the radius along the u value of the curve. The "u" value is derived from the wire primitive itself so you can't change that. To vary the radius, create a channel on the second component of the U Radius parameter. In that channel, set two keys say at frame 1 and at frame 240. Now add keys in between and change the values of the keys to the radius that you want. Quote Link to comment Share on other sites More sharing options...
kstrev Posted April 14, 2016 Author Share Posted April 14, 2016 thank you very much Edward for the explanation. I managed to work it out with a custom value. I have to apologise because I found your post in the houdini forum as well after I wrote here, which is of great help. https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=6702&highlight=wire+capture+lookup I am attaching the file as an example, just in case someone new to Houdini needs a custom radius along the wirecapture. Thanks again wireCapture_v002.hip Quote Link to comment Share on other sites More sharing options...
edward Posted April 16, 2016 Share Posted April 16, 2016 No problem. I must be getting old since I don't remember ever posting a hip file example although I'm sure I've answered questions like this before. Quote Link to comment Share on other sites More sharing options...
