melragheb Posted April 14, 2016 Share Posted April 14, 2016 Hey guys quick question, I need to do some operations on two particle streams\groups using point cloud using a pop vop. fist of all, can I put the pop vop after merging the two streams, or do I need to have it connected to one of the groups before the merge, and how to plugin the two in the pointcloud open? Note:I'm really new to pointcloud, but I've been using TP witch has the same method of groups and searching between the groups! Thanks, Mook Quote Link to comment Share on other sites More sharing options...
anim Posted April 14, 2016 Share Posted April 14, 2016 you can use pcfind() which allows you to specify point group http://www.sidefx.com/docs/houdini15.0/vex/functions/pcfind Quote Link to comment Share on other sites More sharing options...
