Grouping Points in an Array
I currently have an array of points gathered at VOP level, and I'd like to group those points in to deferent group names.
So for instance:
[1, 34, 5] into group 1
[2, 12, 67] into group 2
I'm thinking I may need a for each...
And as a matter of interest could one test if a point was part of a certain array?
thanks
you can use find() function to test if an item is in an array or not http://www.sidefx.com/docs/houdini15.0/vex/functions/find
you can use setpointgroup() function or VOP node to set group membership on non-current point http://www.sidefx.com/docs/houdini15.0/vex/functions/setpointgroup
or i@group_groupname = 1; if you are doing it for current point
Thanks anim but after a bit of tinkering it alludes me.
I'm only getting my head into VEX, I add an inline VEX node into my VOP and type this:  int [] find(arraytype array; type search), but now I'm stumped.
I've basically got an array called "test_pcFind" that looks like this [1,169,513] and all  I want to do is test if these three point's are part of the same array so I can group them.
Any thoughts anyone?
