Thejiminator Posted May 2, 2016 Share Posted May 2, 2016 (edited) I'm a Houdini beginner, so apologies if this is a bit of a simple question I've created a curve at obj level, that I want to follow the path of a pipe geometry My plan is to then use this curve as a popcurveforce to drive particle velocity, pulling the particles up the pipe My problem is that the curve will appear to be linear in the SOP geometry, but when I point my popcurveforce at the same SOP, it appears as a bezier curve in my autodop network I've attached my .hipnc file, I'm working in Houdini Apprentice 15 If anyone can provide some wisdom it'd be much appreciated! Thanks! oil pump.hipnc Edited May 2, 2016 by Thejiminator Quote Link to comment Share on other sites More sharing options...
mine Posted May 4, 2016 Share Posted May 4, 2016 I'm not sure, but maybe you should look at the parameter "guide spacing" in the "guide" tab of the POP Curve Force node. Lower it to 0.1 and you should see your curve right 1 Quote Link to comment Share on other sites More sharing options...
Thejiminator Posted May 5, 2016 Author Share Posted May 5, 2016 On 04/05/2016 at 1:57 PM, mine said: I'm not sure, but maybe you should look at the parameter "guide spacing" in the "guide" tab of the POP Curve Force node. Lower it to 0.1 and you should see your curve right Thanks Mine, worked perfectly! Quote Link to comment Share on other sites More sharing options...
