houdini_constraint——problem
the main problem is that box and teapot have pieces named piece# and that result in the same names for different RBDs so constraints are attached to wrong RBDs
the easies way to resolve this is to give unique names to pieces
the other way is to give more specific names to constraint anchors like DOPobjectname/piecename, e.g. teapot/piece11, but as I said the easiest is to have unique piece names instead
the other problem in your file is some typo in attributes for box constraints so they were not created
look at the file all fixes are green
untitled8explode_fix.hip
