Pose reader
didn't watch the whole tut, but looks like he is interested only in angle and not the whole pose
in your file you are using Dot product, which is not the same as Angle Between in Maya as Dot doesn't return angle but cosine of the angle and on top of that the input vectors need to be normalized and the angle is in radians so according to your Coneangle you wan degrees
since you are transforming all your positions to the same space, using Into This Object on all Object Merge nodes, you don't need Transform VOPs. look at the file
posereader_fix.hip
