Nashrat Shahi Posted May 16, 2016 Share Posted May 16, 2016 Hi, I have two questions....first, why the objects in yellow circle(as shown in image) which are glued is behaving abnormally,actually it should flow with movement of ball but it's still glued and i have tried many values of glue constraint and spaecially at the corners its behaving weird?? Second, why the whole house is getting influenced and started moving on the hit of ball instead of only collision area as shown in .mov playblast ? Thank you.. pb.mov Quote Link to comment Share on other sites More sharing options...
davpe Posted May 16, 2016 Share Posted May 16, 2016 without a sample scene to look into I only can say that you have set it up incorrectly. from what it looks like there is a confusion in the name attributes or something. can't say for sure. Quote Link to comment Share on other sites More sharing options...
anim Posted May 17, 2016 Share Posted May 17, 2016 you are most probably introducing constraints every frame, make sure that expression on Constraint Network/Override with SOP parameter is 1 only on first frame if you are using default expression, make sure that your constraint network is not time dependent or simply replace that constraint with $SF==1 1 Quote Link to comment Share on other sites More sharing options...
Nashrat Shahi Posted May 17, 2016 Author Share Posted May 17, 2016 (edited) Thanx alot Tomas....i am using Houdini 14..... As u told i had changed the default constraint network expression and it worked.... constraint_solved.mov Edited May 17, 2016 by Nashrat Shahi wrong file uploaded Quote Link to comment Share on other sites More sharing options...
Nashrat Shahi Posted May 17, 2016 Author Share Posted May 17, 2016 glue_contraints_script.txt Quote Link to comment Share on other sites More sharing options...
