CaptainAhoy Posted May 19, 2016 Share Posted May 19, 2016 Hi I am using music and CHOPS to change the height of the box and have run into a problem. The height of the boxes is changing too much i.e the height gets really huge in value based on the music. I used an "envelop" node to normalize the height but if I used a value of anything more than 0.2, the boxes don't move as much. They only move if there is a huge change in the music. I have attached a gif with this post. I would want the boxes to still move the way they are moving right now, just not as high. Basically, I am trying to figure out a way limit the max height of the boxes. Kindly assist. Thanks! Quote Link to comment Share on other sites More sharing options...
mestela Posted May 19, 2016 Share Posted May 19, 2016 At a guess without a hip file (always post a hip file!), you could try using a function chop in pow(x) mode to warp the small values higher and the big values lower, then maybe a math chop with the range tab to bring it back to the range you want. Quote Link to comment Share on other sites More sharing options...
CaptainAhoy Posted May 19, 2016 Author Share Posted May 19, 2016 (edited) 3 hours ago, mestela said: At a guess without a hip file (always post a hip file!), you could try using a function chop in pow(x) mode to warp the small values higher and the big values lower, then maybe a math chop with the range tab to bring it back to the range you want. Thanks for your reply. I will try this out Also, sorry about not posting the hip file. I wanted to post the hip file but that would also mean posting the music file Im using. I am not sure what the rules are when it comes to posting music files (as it might be considered illegally distributing / pirating music) If posting music files isnt a problem then I will surely post the hip file. Edited May 19, 2016 by CaptainAhoy Quote Link to comment Share on other sites More sharing options...
mestela Posted May 19, 2016 Share Posted May 19, 2016 or just don't attach the music file, or replace it with a noise like i've done. we can probably find a suitable replacement on our own computers. Quote Link to comment Share on other sites More sharing options...
CaptainAhoy Posted May 19, 2016 Author Share Posted May 19, 2016 (edited) Edit: Edited May 19, 2016 by CaptainAhoy Quote Link to comment Share on other sites More sharing options...
CaptainAhoy Posted May 19, 2016 Author Share Posted May 19, 2016 27 minutes ago, mestela said: or just don't attach the music file, or replace it with a noise like i've done. we can probably find a suitable replacement on our own computers. Yes. That makes more sense haha. Attaching the hip file now. (I can PM you the music file if thats ok) Adell.hipnc Quote Link to comment Share on other sites More sharing options...
mestela Posted May 19, 2016 Share Posted May 19, 2016 Yep, futzing with the audio with range/limit/pow seems to bring it back to reasonable values: Adell_tweak.hipnc Quote Link to comment Share on other sites More sharing options...
CaptainAhoy Posted May 19, 2016 Author Share Posted May 19, 2016 5 hours ago, mestela said: Yep, futzing with the audio with range/limit/pow seems to bring it back to reasonable values: Adell_tweak.hipnc this works great! thanks Quote Link to comment Share on other sites More sharing options...
