manx151089 Posted May 19, 2016 Share Posted May 19, 2016 Hi, Is it possible to convert a bgeo sequence of a fragmented geometry to an animation sequence? If possible, could any one share the workflow? Thanks, Manish Quote Link to comment Share on other sites More sharing options...
paxsonsa Posted May 25, 2016 Share Posted May 25, 2016 It the point count is static. You should be able to load in the SOP into CHOPS with a Geometry Node and it should interpolate between I think? Quote Link to comment Share on other sites More sharing options...
