sebkaine Posted May 27, 2016 Share Posted May 27, 2016 Hi Guys, I want to extract the intersection curves of 2 polygon mesh. I get correct result with the SOP cookie > crease option, but it is slow and base on a node i don't trust that much ... I would like to replicate this by using a SOP clip, i have suceed to extract the section i want , but i am struggling to extract a clean curves from this, If you have any idea that would be great ! Thanks for your time ! E curve_from_cut.hiplc Quote Link to comment Share on other sites More sharing options...
papicrunch Posted May 27, 2016 Share Posted May 27, 2016 divide with remove shared edge ? 2 Quote Link to comment Share on other sites More sharing options...
NNois Posted May 27, 2016 Share Posted May 27, 2016 ok sorry to intercept this guys but, i was searching this for a long time now, how on hell you can fiund "delete edges but keep boundary ones" in "Divide SOP" ??? 50% of tools in houdini are spreads over toons of SOPs with not so desciptive name. Do someone ever wrote a SOP Visual Guide or something ??? Quote Link to comment Share on other sites More sharing options...
f1480187 Posted May 27, 2016 Share Posted May 27, 2016 Here is how to fix Divide SOP limitation about open geometry: // Point Wrangle. #define ALMOST_ZERO 1e-6 vector4 plane = chv("../clip2/dir"); plane.w = ch("../clip2/dist"); float dist = abs(@P.x * plane.x + @P.y * plane.y + @P.z * plane.z - plane.w); if (dist > ALMOST_ZERO) { removepoint(0, @ptnum); } And with it, it should be really fail-proof solution, comparing with Cookie SOP. But in 15.5 there is a new Dissolve SOP which able to create curves from edges, and it works quite good, much better than old one. Give it a try also, if you are up to date. edge_to_curve.hipnc @NNois, I agree, many nodes have such "side features", like Facet's removing inline points by threshold or Divide's removing shared edges. I believe it is what you could get from the main algorithms for free. If you do something like shaders or VEX wrangles, you might notice that you could compute a lot of auxiliary and potentially useful data by outputting inner variables. 4 Quote Link to comment Share on other sites More sharing options...
sebkaine Posted May 30, 2016 Author Share Posted May 30, 2016 Thanks a lot for all your very useful answers guys ! This one was sneaky ... I have assemble a hip that sum up all the methods ... I would also be curious to know how to do this in NURBS in Houdini , cause it was pretty obvious to me that this would be very straightforward , you have 2 nurbs patch and you just want to isolate the intersected isoparm , but i fail to use SOP surfsect correctly , i only get ugly stuff. I might be responsable for that anyway ... Cheers E test_cut_02.hiplc Quote Link to comment Share on other sites More sharing options...
sebkaine Posted May 30, 2016 Author Share Posted May 30, 2016 i have edited the file with the nurbs technics, but nurbs is slow and also not as good as clip ... f1480187 your technics with clip > divide > wrangle look to be the best imo as it is not 15.5 depdendant ... test_cut_03.hiplc Quote Link to comment Share on other sites More sharing options...
