feresteanud
Before starting and explaining what is all about, which is kind of obvious, I've search on this forum and official houdini forum to solve this problem but none of the subjects came across with a straight answer. What I want is simply filling the glass. The collision geometry is really thick, as is suppose to be, added a divergence attribute, which is ridiculous high, just to get the glass filled (as suggested on other posts) but still it's like the glass has a hole somewhere and stays at the same level. See the image at frame 46.
In tried also in realflow and it fills the glass normally. I've attached the file in case someone want's to dig in and have a look. Thank you in advance.
fill_glass.hipnc
It seems that is working. It could have been, as you said, from volume sample and also have to remove from flip object the object. I might have messed up the settings in flip solver, so it's a good idea to start with a fresh solver. Sorry, I have forgotten to upload the proxy glass. My mistake and thank you very much for your quick answer.
