kennyd Posted June 4, 2016 Share Posted June 4, 2016 Good afternoon, I am working on the digital tutors tutorial Creating your own custom Pyro FX in Houdini. For some reason my vopsop or even the attribvop (Houdini 2015's replacement of the vopsop) does not connect the inputs in their respected coded name. Like input 2 should be connected to fuel, but when I middle mouse click to double check, it just highlights and doesn't show the path that op:'opinputpath(".",1)' is supposed to direct it to. Is there an edit to Houdini 2015's op:'opinputpath(".",1)' code? I hope my explanation is good enough to understand, there is a file to show you what I mean. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 5, 2016 Share Posted June 5, 2016 Use backticks `, not single quotes '. Quote Link to comment Share on other sites More sharing options...
anim Posted June 5, 2016 Share Posted June 5, 2016 19 hours ago, kennyd said: ... even the attribvop (Houdini 2015's replacement of the vopsop) does not connect the inputs in their respected coded name.... in Attrib VOP you no longer need to do that through Parameter VOP yourself, if you look inside at Geometry VOP Global Parameters, all input geometry handles are already bound as Opinput1..4 parameters Quote Link to comment Share on other sites More sharing options...
kennyd Posted June 6, 2016 Author Share Posted June 6, 2016 Everything seemed to work out! Thanks for the help guys Quote Link to comment Share on other sites More sharing options...
loogas Posted November 28, 2016 Share Posted November 28, 2016 (edited) On 6.06.2016 at 2:51 AM, kennyd said: Everything seemed to work out! Thanks for the help guys Hi, just a quick question - how did you make it work? Through the old VOPSOP or the new Attribute VOP? I keep getting problems with translating stuff to newer versions of Houdini. I can see what anim suggested but it seems as if the attributes are not comming through - when I plug it in to Cd I don't see any color change. Update: I got it! (after 3 hours of going crazy ). If anybody has a similar "problem": In VOPSOP we didn't have to plug in the P when working with PCOpen, in Attribute VOP/Point VOP even though we don't have to write expressions and can plug in other inputs from "outside/the upper level" directly to PCOpen it doesn't process correctly without the additional P input. Here's a comparison (both versions working): Edited November 28, 2016 by loogas Quote Link to comment Share on other sites More sharing options...
kennyd Posted January 4, 2017 Author Share Posted January 4, 2017 sorry for the late reply, but I got it to work from the first reply Use backticks `, not single quotes '. HNY! Quote Link to comment Share on other sites More sharing options...
