Martin B Posted June 8, 2016 Share Posted June 8, 2016 I posted this over on www.sidefx.com but this site seems to get more love. Still pretty new to Houdini but done some searching around on this topic and could use some input. Hi there, I'm trying to shade a fairly long haired dog which has almost white hair with lots of blonde/yellow coming through on the denser area's, especially when backlit. I'm almost getting there with the inbuilt Hair Shader but was wondering how others are doing this? At the minute I can turn on Transmit Objects which produces a nice backlit effect but is incredibly heavy to render. Is this essentially path tracing dual scattering? The other option is to only use Transmit Lights to get some transmission and use the Fake Caustic options under opacity to lift the darker shadows, which renders quickly but doesn't have the depth of going the full Transmission route. Are there any ways to cheat the dual scattered look? I've had a read of the papers but its a bit beyond me… Any help is much appreciated Martin Quote Link to comment Share on other sites More sharing options...
Martin B Posted June 9, 2016 Author Share Posted June 9, 2016 For those interested I went with having Transmit Objects turned on and dropping the refraction limit right down, this gave 90% of the transmission effect I was getting with a higher limit but rendered in half the time, and then graded that AOV up in comp, along with a little bit of the fake caustics I managed to get a pretty nice soft looking hair with loads of scatter. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 9, 2016 Share Posted June 9, 2016 Hey Martin Thanks for the update. I don't suppose you can post anything from the render? It would be interesting to see the results. M Quote Link to comment Share on other sites More sharing options...
Martin B Posted June 10, 2016 Author Share Posted June 10, 2016 He's some crops from the other day, Beauty, DIFF and TRANS. No texture maps, just white hairs and the transmission pushed to yellow. Its had a fair bit more work done to it since, texture maps, getting more control over tip/root blending, figuring out the specular and wet mouth stuff, not a million miles off the live action dog, bit more love and some comp work should be good. Quote Link to comment Share on other sites More sharing options...
