Copying Constraints?
mstarktv
I am super stuck on trying to create constraints across multiple copied geometry. I attached my file to make more sense of it. If you open the DOP Network you can see that from left to right I have a position constraint>rotation>rotation. However, I'm confused on why the second rotation constraint isn't connecting to the 1st. It acts as if it's just a position constraint with a rotation constraint on it.
Hopefully my file explains more. It's kind of a mess because I tried to copy the constraints across instead of making a new line each time. Trying to learn the most basic form of using constraints so any help is much appreciated.
constraint.hipnc
The reason why it's not connecting is because you are connecting to a nonexistent box3. When creating constraints, you got a primitive with two points(your line). The name attribute of each point tells the constraint net which geo it should connect. So point 0 connects to box0 and point 1 to box1. Point 0 and point 1 are one primitive and therefore hold together. I hope the image makes it a bit clearer what I mean. Attached there is your scene with the constraint visualization. Note that if you want to use that setup you would have to scale down the points since I left them apart for visualization purposes only.
Hope that helps.
Dennis
constraint_visualize_v01.hipnc
Edited by DennisSchmidt
This cleared a lot up for me. For some reason I was only paying attention to the constraints and not the boxes themselves. I was looking at "box*" as just a name and totally forgot that it's an actual object. Brainfart... Thanks, Dennis!
Hope that helps.
Dennis
When I started diving down into your setup I noticed something that I was going to ask. Which was that, you made it so that the box count could be copied to the line count. However, once I went to 4 boxes (box3). It seemed to just break and only the first 3 were connected. Is there any specific reason for this? Again, thanks! I'm just trying to really understand.
It works for me. I just changed the copy of the boxes from 3 to 4(did you do the same?) and the copy of the lines also to 4. That was it. I think you forgot to add to the number of line copies. So there is no constraint created. A good way to check is looking at your geo spreadsheet. There you would see if there is a point connected to box3. If you select the OUT_ROT1 and look in the spreadsheet of the attached file you can see that point 5 is connected to box3. The second point belonging to that primitive is point 4 and it is connected to box2. Therefore, it should hold box2 and 3 together.
Hope that clears it up a bit.
constraint_visualize_v02.hipnc
  • 1 month later...
Hello! Sorry for awakening this thread again.
But what about copying the whole setup multiple times? I played with loops but didn't get it right.
Are loops even a worthwhile approach?
Thanks in advance.
Edit: Partially solved, I just put the assemble in the wrong place, no loops this time.
Now on to massage the old % to get the first piece of every copy cluster to points on another rigid body.
Edited by Hamp
Partially solved.
If you could share your file, would be interesting. As always there are a ton of ways to do this. It all depends on the needs and how procedural it should be.
Attached you can find a quick and "dirty" approach. The changed or added nodes are colored yellow. Maybe later i will find some time to build a more elegant version.
constraint_visualize_v03.hipnc
