VEX Get Path Matrix In SOPs?
Atom
I have a NULL at the object level moving along a path.
I have another GEO object that pulls in a source mesh.
I want that source mesh to follow the path as well. However, I am inside SOPs.
I am looking for the VEX code that will transfer the NULL object matrix into the Translate, Rotate and Scale XYZ values of a Transform node at the SOP level.
I can fetch the matrix from the object but I am not sure how to assign it?
matrix m = optransform("obj/null_FOLLOWS_PATH", @Time);
//rotate ( m, radians ( 20 ), { 0, 1, 0 } );
v@path_P *= m;
Here is some pseudo code to demonstrate the intention of the code I am looking for.
	v@my_pos = m.extract_transform();
	v@my_rot = m.extract_rotation();
	v@my_scale = m.extract_scale();
Edited by Atom
Thanks F1, that is a great example file. I think the transform by attribute is the simplest for my needs.
But the explicit code example is valuable as well.
#include <math.h>
#define XFORM_T 0
#define XFORM_R 1
#define XFORM_S 2
matrix xform = optransform("/obj/null1");
vector pivot = {0,0,0};
v@t = cracktransform(XFORM_SRT, XFORM_XYZ, XFORM_T, pivot, xform);
v@r = cracktransform(XFORM_SRT, XFORM_XYZ, XFORM_R, pivot, xform);
v@s = cracktransform(XFORM_SRT, XFORM_XYZ, XFORM_S, pivot, xform);
Edited by Atom
