Circle radius driven by distance to curve.
Tomasz Dabert
I am begginer in Houdini so my problem is rather simple for most of you:) I wanted to make a tool that will scatter circles on surface and later the radius of the circles will be driven by the distance to the curve I drew on top of it (as in the picture). It is important that the radius will start to shrink only if distance is smaller then a certain value that I choose. Where would you guys start? Thanks in advance!
Have no idea what you are trying to do but, here is a quick method using the attribute transfer. Just adjust the deistance threshold or the blend width on the attritransfer to see what is going on. Definitely more than one way to pull off radius scaling like this though.
circle_radius.hipFetching info...
Edited by rbowden
  On 6/20/2016 at 10:03 PM, konstantin magnus said:
yes, attributetransfer + copy-stamping.
circles.hipncFetching info...
Expand
copy stamping is overkill for this :P,
personally I would just use a wrangle to calculate the distance
and apply a simpe pscale for the second copy input.
That should be enough for this (and will be faster if you want to go ultra-high resolution)
granted, copy stamping could be the best "beginner" solution...
Edited by acey195
  On 6/21/2016 at 7:12 PM, Tomasz Dabert said:
How would you use the point wrangler?
Expand
You can put a function like "xyzdist" into the pointwrangle and connect it to the copy SOP.
f@pscale = xyzdist(@OpInput2, @P);
 As Twan mentioned its faster (and more compact). :D
circles2.hipncFetching info...
Edited by konstantin magnus
