JoyceK Posted June 27, 2016 Share Posted June 27, 2016 Hi I want to ask a simple question, how to unscope parameter that is scoped using the shift + LMB shortcut? I can't unscope by clicking elsewhere, I figured out if I click other object in the network it will scope that object, then I can deselect by clicking elsewhere. So is there any other way? Quote Link to comment Share on other sites More sharing options...
3dome Posted June 27, 2016 Share Posted June 27, 2016 (edited) well, within the animation editor bottom left you can see all scoped channels. From there just select the ones you need. If you need to see the "unscoped" curves again, just select them again. Hope that's what you're looking for Edited June 27, 2016 by 3dome typo 1 Quote Link to comment Share on other sites More sharing options...
JoyceK Posted June 28, 2016 Author Share Posted June 28, 2016 Thanks for the suggestion 3dome. It is what I'm looking for. From there I found out that you can right click at the 'scoped parameters' window and select 'unscope all' or using the shortcut 'c'. Quote Link to comment Share on other sites More sharing options...
