Tracking Sop elements for Smoke Clusters [SOLVED]
sekow
hey
I cant figure out how to resize smoke fields when using clustering via point instancing.
When I use the smoke source, it wont take the clusters into account, instead using the bound of all clusters together.
But I like to resize the smoke clusters accordingly
see attached hipfile
SMOKE_CLUSTER_TRACKING.hip
Edited by sekow
found it. its not a bug.
inside the sop solver (in the dynamic resize dop) that is responsible for setting up ResizeBounds, is a Object merge sop (see new hipfile)
There is a group parameter that should be exposed.
just put in: @name=density_`dopfield("..",stamp("..", "OBJID",0),"init","Options",0,"init_cluster")`
nad yall good to go...
SMOKE_CLUSTER_TRACKING_2.hip
