ikoon Posted June 29, 2016 Share Posted June 29, 2016 Please, in the attachment ... am I using the Fetch and Export chop right? Is there another or better way to export one single parameter or attribute to chop > edit in chops > import back to SOP? In the attachment, I have also tried to use "one point geometry" and use Channel SOP to import single animated channel. I know it is a dumb way, but why is it not working? I have tried both @myvalue and $MYVALUE. channel import.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted July 4, 2016 Share Posted July 4, 2016 (edited) Your exporting to chops seems to be working, as far as fetching the data you can use a Hscript function for that. Set the Display Flag on sphere1 and place this code in the Uniform Scale field. You will see that the radius of the sphere matches the CHOPNET channel. chop("../chopnet1/rename1/domainv0") Edited July 4, 2016 by Atom 1 Quote Link to comment Share on other sites More sharing options...
