kruasan05 Posted July 18, 2016 Share Posted July 18, 2016 (edited) Hi guys! How to make the particles are only on the surface as in this example . In my case most of the particles are under water . https://dl.dropbox.com/s/o1j4oqns3wdt3l7/Снимок7777.PNG?dl=0 It bubbles, but in the example they are all on the surface https://dl.dropbox.com/s/6vffkjuv3xyzxfk/Снимок123654.PNG?dl=0 which the author uses to do so. I cuts flipsurface, by bounding volume for top surface field, but most of the particles is still under water . Foam is not enough. I need more foam above the surface. Edited July 18, 2016 by kruasan05 Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 19, 2016 Share Posted July 19, 2016 You can check this tutorial. http://www.cgsociety.org/training/course/fluids-fx-using-houdini Following this tutorial You can add extra foam with using vops. Also you can increase buoyancy in Y for bubbles, so they reach surface faster and turn into foam. 1 Quote Link to comment Share on other sites More sharing options...
kruasan05 Posted July 20, 2016 Author Share Posted July 20, 2016 19 hours ago, cudarsjanis said: You can check this tutorial. http://www.cgsociety.org/training/course/fluids-fx-using-houdini Following this tutorial You can add extra foam with using vops. Also you can increase buoyancy in Y for bubbles, so they reach surface faster and turn into foam. Thank you very much Janis. Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 20, 2016 Share Posted July 20, 2016 Also what I did once, I just wrote out .bgeo with all particles and before rendering used transform to lift it up on y axes a bit. Also one way to fake it a bit. Shame that for getting more foam if you increase particle count, you get more bubbles as well. and I got to a point where my system couldn`t handle it. and crashed. cant afford 64 Gb RAM, That`s why I used this vops for adding foam. But Graham`s simulations are all great and something to look up to and reach to 1 Quote Link to comment Share on other sites More sharing options...
kruasan05 Posted July 20, 2016 Author Share Posted July 20, 2016 6 minutes ago, cudarsjanis said: Also what I did once, I just wrote out .bgeo with all particles and before rendering used transform to lift it up on y axes a bit. Also one way to fake it a bit. Shame that for getting more foam if you increase particle count, you get more bubbles as well. and I got to a point where my system couldn`t handle it. and crashed. cant afford 64 Gb RAM, That`s why I used this vops for adding foam. But Graham`s simulations are all great and something to look up to and reach to Graham was used 32 gb in this sim. In my case 80 mln core. 60 in WW. Ram 32 gb Quote Link to comment Share on other sites More sharing options...
