Point normals with Wire Deform SOP
Hi all,
I have a problem with wrong point normals.
Basically I have an L-system vine which I am deforming with Wire Deform SOP. I am separating the 'anchor points' of the leaves and I want to add the leaves back after the Wire Deform SOP (if I keep the leaves geometry together, the wire deform screws up the leaf geometry). I also want to do it this way, as I want to control the leaves animation and growth with copy stamping which won't be possible if I keep everything together.
But if I separate the anchor points and then add the leaves back with copy SOP, the point normals are different that those I would get if I deform the whole L-system together.
I hope it makes sense, any suggestions how to fix it would be greatly appreciated.
I attached screenshots and my .hip file with both set ups.
Correct normals, screwed up geo:
Screenshot from 2016-07-21 19:11:35.png
Wrong normals, correct geo
Screenshot from 2016-07-21 19:11:42.png
normals_lsystem_problem.hipnc
