What is best way to render out to Adobe After Effects?
Hello,
I have a question.
How to render out animation in HD (i do not want to loose a animation quality):
I need a tiff sequence at the moment.
At the moment i am using Mantra to render out and i am rendering TIF sequence files
with resolution 1280 x 720
I want to import that TIF sequence later to Adobe After Effects where i continue my work.
At the moment i am using Intel Core i7 CPU (3.20 GHz)
6BG Installed memory (ram)
and using 10 000 rpm hdd drive (as my SSD went bad)
I have installed windows 10
My FIle is total 900 frames
Mantra has rendered allready 61 hours and 55 minutes.
and has done 100 frames from 900 frames
What should i turn of in this case?
Note! I do not want to loose render quality and images it renders out should look like you see in picture that i attached.
Logo_99.tif
Black.mass.from.scratch.with.hip
Not sure but you could try to redesign the shaders as the time is taken up in the refraction. Dropping the Refraction limit increases the speed a lot.
