Offset copied lines
Hey guys,
I'm trying to replicate some UI stuff in houdini as a way to practice and learn.
Here's what I got so far
And here are some samples of what I'm trying to get
My main question is how to offset the lines of the copy so they don't start all at the same position, I tried an attribute vop and connected the position to a random but doesn't work, I also tried the carve node and a attribute vop for the velocity but also isn't working.
Lastly on the samples there are some lines that are more contrasted to others, I get a similar look with an attribute random with "alpha", but that changes the alpha of the overall circle instead of just some cut lines as the samples.
As for different directons of noises, I played with noises in attribute vop and directed them by a float to vector and then a vector to float to chose if they act in x y or z, is this a good way to do this?
Attached is my hip file
Thanks in advice
houdini ui2.hipnc
You can drive noise effect using primitive number. And probably add another noise layer to introduce anomalies, which doesn't account for it. I think the rest is a combination of small tweaks to both values. To carve randomly, you can rotate each primitive by creating random angle primitive attribute and rotate it with Primitive node.
rings.hipnc
rings.hipnc
@f1480187 thanks a lot! great setup, i'm learning a lot from it! still analizing some stuff, cheers!
