logix1390 Posted July 28, 2016 Share Posted July 28, 2016 Hello, So I have a simple pyro sim using the shelf tools. I want to hide the emitter . How would I go about doing that? I tried searching for this but all I got was this thread here: He is trying to hide it with another box and subtract it ...but this method isn't the best for what i'm trying to do. Is there another way ? Thanks Quote Link to comment Share on other sites More sharing options...
rbowden Posted July 28, 2016 Share Posted July 28, 2016 If a box won't work for you, you can always take your original emitter and do the same steps as Miles stated in that thread. Attached is a quick example. volume_delete_source.hip Quote Link to comment Share on other sites More sharing options...
logix1390 Posted July 28, 2016 Author Share Posted July 28, 2016 Oh wow.. yea that makes sense, i should have figured that one out. Appreciate the help. Is there a way to feather it out , lets say i wanted to delete a little more ? Thanks again Quote Link to comment Share on other sites More sharing options...
carlo_c Posted July 29, 2016 Share Posted July 29, 2016 Had a quick look at the hip file, you can drop a transform before the isooffset to change the size as you see fit before converting to a volume to take as much or less away as you need. You can also try using the volume tools there are things such as volume blur, volume feather etc. all hiding under the volume section in the tab menu Quote Link to comment Share on other sites More sharing options...
logix1390 Posted July 31, 2016 Author Share Posted July 31, 2016 Perfect! Thanks for the help carlo ! Quote Link to comment Share on other sites More sharing options...
