saca Posted July 29, 2016 Share Posted July 29, 2016 Hi, I tried River simulation. Simulated river body is no problem. but whitewater spray particles are leaking from ground geometry. (foam and bubble particles are no problem.) Whitewater sim(DOP) made with shelf tool, I have added static object geometry(volume) into whitewater simulation. why spray can not collided? DOP substeps 1 or 15 or higher,can not solve this problem. thanks. Houdini 15.0.459 Windows7 Quote Link to comment Share on other sites More sharing options...
bunker Posted July 29, 2016 Share Posted July 29, 2016 (edited) the inputs of your "merge1" node are in the wrong order. Edited July 29, 2016 by bunker Quote Link to comment Share on other sites More sharing options...
gaurav Posted July 29, 2016 Share Posted July 29, 2016 You may ask How did bunker figure that out ? with experience of course. But if you are new to Dops best place to look for this info is details view. Important thing to remember is that Merge node in dops doesn't merge multiple data streams in Sops sense but it creates relationships. Relationship data is the one that tells dops dynamic engine which object affect which other object. Affector Matrix(Table) in dops Details view is very useful in figuring that out. Top row is of Affector objects and left col is Affected objects. Green color is two way, Blue is one, and grey no color means no relationship. If you hove rover cells you get the popup text. Play around with different Affector relationship types on Merge node to see how it reflects in this table. Cheers ! 2 Quote Link to comment Share on other sites More sharing options...
bunker Posted July 30, 2016 Share Posted July 30, 2016 or simply click on the merge node, the default is set to: Affector Relationship: Left Inputs Affects Right Inputs Quote Link to comment Share on other sites More sharing options...
saca Posted August 1, 2016 Author Share Posted August 1, 2016 thanks, I'm new to DOP and houdini. I understood rerationship and input-order. Houdini shows me the status of deta very well. few particle are leaking, but they are made more better with higher substeps. Quote Link to comment Share on other sites More sharing options...
