JesseVFX Posted August 1, 2016 Share Posted August 1, 2016 (edited) i bind export P parameter as a parameter called Direction and N,but after the copy sop , the Direction is different from N 。Why? Can i correct it except the right method ? Did i miss something ? here is an example file below (Houdini 15.0.313) thanks Copy Sop Problem.hip Edited August 1, 2016 by JesseVFX Quote Link to comment Share on other sites More sharing options...
benne5 Posted August 1, 2016 Share Posted August 1, 2016 Hi Jesse, If I understand your problem correctly I beleive that you want to check on the "Use Template Point Attributes" selection located on the attributes tab of your copy node. Cheers Quote Link to comment Share on other sites More sharing options...
bluciensky Posted August 1, 2016 Share Posted August 1, 2016 If you uncheck 'transform using template point attribute' on copy SOP, it will work, but I think that's not the result you want. This happens when you copy volumes(ex - 'vel' field will be messed up, so that you need to rotate it afterward). Quote Link to comment Share on other sites More sharing options...
cgnema Posted August 2, 2016 Share Posted August 2, 2016 Hi Jessie, The reason they are different is because the copy sop is transforming (rotating) the N but not the Direction attribute you created. When you create a vector attribute with a bind in vops: it makes it a float[3], so if you look in your geo spreadsheet the Direction attribute will show direction[0], direction[1], direction[2]. But N has N[x],N[y],N[z]. The [xzy] indicates that the attribute should be transformed by any operations that do transformations (like the copy sop with "Transform" using template point attributes). The direction however shows [012] so it will not be transformed. You can fix this with an add attribute node with "Type Info" set accordingly. attributeTypeInfo.hipnc Quote Link to comment Share on other sites More sharing options...
JesseVFX Posted August 2, 2016 Author Share Posted August 2, 2016 13 hours ago, cgnema said: Hi Jessie, The reason they are different is because the copy sop is transforming (rotating) the N but not the Direction attribute you created. When you create a vector attribute with a bind in vops: it makes it a float[3], so if you look in your geo spreadsheet the Direction attribute will show direction[0], direction[1], direction[2]. But N has N[x],N[y],N[z]. The [xzy] indicates that the attribute should be transformed by any operations that do transformations (like the copy sop with "Transform" using template point attributes). The direction however shows [012] so it will not be transformed. You can fix this with an add attribute node with "Type Info" set accordingly. attributeTypeInfo.hipnc thank you Nema !!! that's the problem. Is that a bug or something ? why I export it as a vector and it will be a 3f ? Quote Link to comment Share on other sites More sharing options...
cgnema Posted August 2, 2016 Share Posted August 2, 2016 You're welcome! Im really not sure, maybe they wanted to avoid custom attributes being transformed by default. Quote Link to comment Share on other sites More sharing options...
