ISUther Posted August 8, 2016 Share Posted August 8, 2016 Hello, I have animation that i do like. I need object to change material smoothly to new material. How to do it? Quote Link to comment Share on other sites More sharing options...
vijay_7363 Posted August 11, 2016 Share Posted August 11, 2016 In shop network> create a vopmaterial, go inside vopmaterial and create two surfacecolor nodes. now create a mix node and connect color channel of both surfacecolor nodes into input1 and input2 of mix node. now for smooth transition create a ramp parameter and connect it to bias of mix node. and to output the result connect blend from mix node to Cf of surface_output node. now adjust your ramp parameter: ramp type to Spline Ramp(float) , keep only one point in your ramp. animate that point's value from 0 to 1 to get smooth transition of your material. Quote Link to comment Share on other sites More sharing options...
