Funny quick tip
Yon
If your probably undiagnosed with mild OCD like myself, heres a little tip
Press D in your network
Grid and Snapping
Check snap to grid and the top left pin
Then enter 1.14 and .3 into the spacing.
Change Grid Display to lines
Now your network has a backdrop of boxes exactly the same size as nodes hahah
  • Like 8
Nice. Can i add?
Group SOP - Can't say how many times i see people manually entering boundary edges or points for geometry with a hole in it. Group Sop - Edges - Unshared Edges. Can be for points or edges.  I think it is often overlooked.
  • Like 2
8 minutes ago, abvfx said:
Nice. Can i add?
Can be primitives too actually ;) I also do use the unshared groups all the time
20 hours ago, konstantin magnus said:
Is there a way to make this default?
If you go to Windows and Save Desktop As it will save your entire UI setup including the backdrop. Then in Preferences somewhere there is a drop down menu to select what desktop to load by default.
