Create SHOP Tool Item?
Atom
Hi All,
I am trying to create an item from the SHOP tool area using python.
For galleries, this code works.
gal_entry = hou.galleries.galleryEntries('mantrasurface')[0]
gal_entry.createChildNode(hou.node("/shop"))
But when I try to use this style of code to create a material node found under Tools the above code does not work because the item does not reside in the gallery.
How would I, for instance, create a FBX Surface Shader using python?
Edited by Atom
