static solver even necessary?
squardis
when you look in the help docs it says the static solver does absolutely nothing. so no, you dont need it. just merge your static objects and your sovler. but make sure the merge is set to "left input affects right" and have your statics be the left = first input and solver being right = second
(if that is the merge mode you need)
Edited by 3dome
  • Like 2
  • 3 weeks later...
1 hour ago, squardis said:
solved!
hnx, I have to look more in the help docs.
but asking cant hurt I think ;)
so why the static solver is stil there?
The static solver is there for legacy reasons, and if you need to switch to a null solver for whatever reason at some point in the solve.
