Outputs greyed out when tryng to make an HDA in CHOPS
I am trying to make some hda's to help speed up and distribute my mocap cleaning process, however when I make an HDA in CHOPS I get an error saying the sub-network has no output, and when I go to edit operator type properties, sure enough the outputs are greyed out. Anyone have an idea on how to fix this?
I think you just need to change the "SubNet CHOP" parameter on your asset so that it points to one of the internal nodes. I created a test node and when I did that it worked.
The Maximum Outputs is probably grayed out because chops doesn't support multiple outputs from a subnet.
