Sopsolver want to import into another object.
saelly
The boxes already are in the SOP solver, but they are packed. If you want to change geometry, you need to unpack them, edit them, then repack them - which can be expensive, depending on what you want to do.
So the easiest question is, what do you want to do in the SOP solver?
thanks reply
I want to control both the sphere and the box in the Solver.
v, and w attributes will control them.
