catchyid Posted August 30, 2016 Share Posted August 30, 2016 Hi, In a network view, you can bypass any node by clicking the "bypass" flag. Now I want to do this programmatically on a SOP Solver, basically turn it off at frame 1 then turn it on afterwords. The problem is I cannot see any "Activation" parameter on the SOP Solver node, hence I have no way to turn off/on the entire solver. What is the right way to do that? Thanks Quote Link to comment Share on other sites More sharing options...
cwhite Posted August 30, 2016 Share Posted August 30, 2016 You could use an Enable Solver or a Switch Solver 1 Quote Link to comment Share on other sites More sharing options...
catchyid Posted August 30, 2016 Author Share Posted August 30, 2016 Thanks, that was easy Quote Link to comment Share on other sites More sharing options...
