papaface Posted September 1, 2016 Share Posted September 1, 2016 what's the difference between substeps on dopnet and min/max substeps on solvers. If the substeps on dopnet is set to 10.The globle parameter @Frame is increased by 0.1 every substep. If the substeps on dopnet is set to 1,the min/max substeps on popsolver are set to 10.@Frame doesn't change during substeps. Why is that? Quote Link to comment Share on other sites More sharing options...
haggi Posted September 1, 2016 Share Posted September 1, 2016 If you use solver substeps, only this solver gets more substeps. Imagine you have more solvers in your dop network, a fluid solver, a rigid body solver, a popsolver. If you see that the popsolver needs more substeps, you can increase the substeps on the dop node, but this increases the substeps for all nodes in the networks, even for those which may not need it. If you do it on solver level, only the nodes does substepping which really need it. Quote Link to comment Share on other sites More sharing options...
sekow Posted September 1, 2016 Share Posted September 1, 2016 sidenote: that also applies to all connected sources too. so if you sourcing points from sops make sure that dops is able to fetch inbetween frames. use $T or $FF instead of just $F Quote Link to comment Share on other sites More sharing options...
papaface Posted September 1, 2016 Author Share Posted September 1, 2016 On 9/1/2016 at 3:02 PM, haggi said: If you use solver substeps, only this solver gets more substeps. Imagine you have more solvers in your dop network, a fluid solver, a rigid body solver, a popsolver. If you see that the popsolver needs more substeps, you can increase the substeps on the dop node, but this increases the substeps for all nodes in the networks, even for those which may not need it. If you do it on solver level, only the nodes does substepping which really need it. Expand Thanks.that's helpful. If I use solver substeps on a popsolver ,and use impluse emission.I do get more particles,which means the source node is affected.but would those nodes wired into this popsolver be affected? and how can I tell whether the operator is cooked on a substep.because I want more substeps,but I don't want some code/nodes work on substeps. Quote Link to comment Share on other sites More sharing options...
sekow Posted September 1, 2016 Share Posted September 1, 2016 there is a gasintermittentsolve dop node for such scenarios. Quote Link to comment Share on other sites More sharing options...
Yon Posted September 1, 2016 Share Posted September 1, 2016 The min/max on solver is a adaptive substep that depends on the CFL condition. CFL is how far something travels in a frame. If your object breaks the CFL limit a substep will be added. It is better to use this then the option on dopnet. The dopnet option will brute force run the substep value every frame. @Frame doesn't change because your particles have not broken the CFL limit to trigger substeps. Quote Link to comment Share on other sites More sharing options...
