Pyro Not Supported By Alembic Export?
Atom
Hi All,
I have a pyro sim and I thought I would try out the Alembic format for saving this. The result is shown in the viewport by the pyro_import node which contains two volumes, density and velocity. I choose File/Export/Alembic and select the pyro_import node for the Source Object Export path and the full frame range for my animation.
I click Export and Houdini goes into sim cooking mode and takes a while.
When I import the Alembic back into my scene I see nothing. I check the filesize and it is only 2K.
I thought Alembic was a panacea, a cure for everything?
Can Houdini store a pyro sim inside an Alembic file?
That export menu is just a shortcut to an Alembic ROP; you should convert volumes to VDB and write them in VDB format.
Not at all. It has capabilities that are improved all the time.
