mohamaedkamal Posted September 8, 2016 Share Posted September 8, 2016 how I can type a houdini render commad form window cmd instead of houdini command tool Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted September 8, 2016 Share Posted September 8, 2016 (edited) The "Command Line Tools" terminal is setup so the bin directory for the Houdini install is added to the path. If you're not using that terminal you have to give the full executable path in the command. So instead of just using "mantra" you'd use something like this that includes the full path. "C:\Program Files\Side Effects Software\Houdini 15.5.565\bin\mantra.exe" -f "D:\prjects\archives\shot01_0004.ifd" If you want to be able to type just "mantra" in any terminal and have it work you could add the bin directory for a specific Houdini version to the path. It's a bit goofy in Windows. http://www.howtogeek.com/118594/how-to-edit-your-system-path-for-easy-command-line-access/ Edited September 8, 2016 by lukeiamyourfather 1 Quote Link to comment Share on other sites More sharing options...
mohamaedkamal Posted September 8, 2016 Author Share Posted September 8, 2016 1 hour ago, lukeiamyourfather said: The "Command Line Tools" terminal is setup so the bin directory for the Houdini install is added to the path. If you're not using that terminal you have to give the full executable path in the command. So instead of just using "mantra" you'd use something like this that includes the full path. "C:\Program Files\Side Effects Software\Houdini 15.5.565\bin\mantra.exe" -f "D:\prjects\archives\shot01_0004.ifd" If you want to be able to type just "mantra" in any terminal and have it work you could add the bin directory for a specific Houdini version to the path. It's a bit goofy in Windows. http://www.howtogeek.com/118594/how-to-edit-your-system-path-for-easy-command-line-access/ thankx very much I want to ask you " I want to build a ios app to mange like a render schedule how I can acess to the render schedule throught command line Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted September 8, 2016 Share Posted September 8, 2016 Like a queue manager? That's an entirely different can of worms that will take a significant amount of time to create. I suggest starting by looking at how other queue managers work. 1 Quote Link to comment Share on other sites More sharing options...
mohamaedkamal Posted September 10, 2016 Author Share Posted September 10, 2016 I On ٩/٩/٢٠١٦ at 0:33 AM, lukeiamyourfather said: Like a queue manager? That's an entirely different can of worms that will take a significant amount of time to create. I suggest starting by looking at how other queue managers work. I want to build a ios app for me like a queue manager , can I acess to queue manager from command line or not , Quote Link to comment Share on other sites More sharing options...
